> Astm
HELGA 21
сообщение 31.5.2017, 15:02
Пользователь №: 174139
Ищу:
ASTM A388/A388M-16a Standart Practice for Ultrasonic Examination of Steel Forgings.
ASTM E647-15 Standart Test for Measurement of Fatigue Crack Growth Rates.
ASTM E111 Test Method for Young`s Modulus, Tangent Modulus, and Chord Modulus.
ASTM E647-15e1 Standart Test Method for Measurement of Fatigue Crack Growth Rates.
ASTM A388/A388M Standard Practice for Ultrasonic Examination of Steel Forgings
ISO 6892-1:2016 Metallic materials. Tensile testing. Part 1: Method of test at room temperature
ISO 148-1:2016 Metallic materials. Charpy pendulum impact test. Part 1: Test method
ISO 148-2:2016 Metallic materials. Charpy pendulum impact test. Part 2: Verification of testing machines
ISO 148-3:2016 Metallic materials. Charpy pendulum impact test. Part 3: Preparation and characterization of Charpy V-notch test pieces for indirect verification of pendulum impact machines
ISO 6508-1:2016 Metallic materials. Rockwell hardness test. Part 1: Test method
ISO 6508-2:2015 Metallic materials. Rockwell hardness test. Part 2: Verification and calibration of testing machines and indenters
ASTM E21-09 Standard Test Methods for Elevated Temperature Tension Tests of Metallic Materials
ASTM E23-16b Standard Test Methods for Notched Bar Impact Testing of Metallic Materials
ASTM E208-06 (2012) Standard Test Method for Conducting Drop-Weight Test to Determine Nil-Ductility Transition Temperature of Ferritic Steels
ASTM A956-12 Standard Test Method for Leeb Hardness Testing of Steel Products
ASTM E1921-17a Standard Test Method for Determination of Reference Temperature, To, for Ferritic Steels in the Transition Range
ASTM E1820-16 Standard Test Method for Measurement of Fracture Toughness
ASTM E647-15e1 Standard Test Method for Measurement of Fatigue Crack Growth Rates
Заранее спасибо.
Ответов (1 - 2)
snti
сообщение 31.5.2017, 19:06
Из: Пермь
Пользователь №: 18280
все есть на рутрекере в раздачах ASTM и ISO
solarscream
сообщение 14.8.2025, 13:30
Пользователь №: 281607
Ищу стандарт ASTM A240/A240M-25a "Standard Specification for Chromium and Chromium-Nickel Stainless Steel Plate, Sheet, and Strip for Pressure Vessels and for General Applications" в формате pdf.
RSS Текстовая версия Сейчас: 20.5.2026, 12:52
