> Стандарты MSS, Стандарты на трубопроводную арматуру и фитинги
moorch
сообщение 24.5.2013, 11:12
Пользователь №: 7391
Сайт The Manufacturers Standardization Society (MSS)
Ссылка
Ну что ж, начнем:
Цитата(yergat @ 24.5.2013, 11:58) *
Коллеги ищу MSS SP-58 Трубопроводные подвески и опоры – материалы, проектирование и изготовление
MSS SP-58-2009
Pipe Hangers and Supports - Materials, Design, Manufacture, Selection, Application, and Installation (ANSI-approved American National Standard)
Сообщение отредактировал moorch - 24.5.2013, 11:29
Прикрепленный файл  MSS_SP_58_2009.pdf ( 923,95 килобайт ) Кол-во скачиваний: 579
3 страниц V   1 2 3 >
Ответов (1 - 29)
moorch
сообщение 24.5.2013, 11:25
В свою очередь ищу:
MSS SP-6-2012 Standard Finishes for Contact Faces of Pipe Flanges and Connecting-End Flanges of Valves and Fittings
MSS SP-9-2013 Spot Facing for Bronze, Iron, and Steel Flanges
MSS SP-25-2008 Standard Marking Systems for Valves, Fittings, Flanges and Unions
MSS SP-42-2009 Corrosion Resistant Gate, Globe, Angle and Check Valves with Flanged and Butt Weld Ends (Classes 150, 300 & 600)
MSS SP-43-2013 Wrought and Fabricated Butt-Welding Fittings for Low Pressure, Corrosion Resistant Applications
MSS SP-53-2012 Quality Standard for Steel Castings and Forgings for Valves, Flanges, Fittings, and Other Piping Components - Magnetic Particle Examination Method
MSS SP-54-2013 Quality Standard for Steel Castings for Valves, Flanges, Fittings, and Other Piping Components - Radiographic Examination Method
MSS SP-55-2011 Quality Standard for Steel Castings for Valves, Flanges, Fittings, and Other Piping Components - Visual Method for Evaluation of Surface Irregularities (ANSI-approved American National Standard)
MSS SP-137-2013 Quality Standard for Positive Material Identification of Metal Valves, Flanges, Fittings, and Other Piping Components
MSS SP-142-2012 Excess Flow Valves for Fuel Gas Service, NPS 1½ through 12
MSS SP-143-2012 Live-Loaded Valve Stem Packing Systems
MSS SP-144-2013 Pressure Seal Bonnet Valves
moorch
сообщение 24.5.2013, 11:45
Выкладываю:
MSS SP-44-2010
Steel Pipeline Flanges
MSS SP-58-2009
MSS SP-61-2009
Pressure Testing of Valves
MSS SP-88-2010
Diaphragm Valves
MSS SP-110-2010
Ball Valves Threaded, Socket-Welding, Solder Joint, Grooved and Flared Ends
MSS SP-121-2006
Qualification Testing Methods for Stem Packing for Rising Stem Steel Valves
MSS SP-126-2007
Steel In-Line Spring-Assisted Center Guided Check Valves
MSS SP-138-2009
Quality Standard Practice for Oxygen Cleaning of Valves & Fittings
Гость_Pitya_*
сообщение 25.8.2013, 12:58
Так же ИСЧУ:
MSS SP-67-2011. Butterfly valves.
SP-80-2013. Bronze Gate, Globe, Angle, and Check Valves.
Mожет есть у кого?
moorch
сообщение 21.11.2013, 12:28
MSS SP-79-2009
Socket Welding Reducer Inserts
Заменен на MSS SP-79-2011
Прикрепленный файл  MSS_SP_79_2009.rar ( 521,92 килобайт ) Кол-во скачиваний: 263
moorch
сообщение 3.7.2014, 9:58
MSS SP-69-2003
Pipe Hangers and Supports – Selection and Application
NOTICE:
This Standard Practice has been withdrawn as an active American National Standard effective 6/06/2014. The contents of this Standard Practice is now part of ANSI/MSS SP-58-2009, which can officially be utilized and referenced in place of SP-69. The withdrawn standard will remain available from MSS as a historical document.
Прикрепленный файл  MSS_SP_69_2003.pdf ( 1,35 мегабайт ) Кол-во скачиваний: 280
DenissPek
сообщение 7.7.2014, 11:51
Из: Tallinn
Пользователь №: 190635
MSS SP-6-2007 Standard Finishes for Contact Faces of Pipe Flanges and Connecting-End Flanges of Valves and Fittings Прикрепленный файл  MSS_SP_6_2007.pdf ( 389,67 килобайт ) Кол-во скачиваний: 239
DenissPek
сообщение 28.6.2016, 9:20
Из: Tallinn
MSS SP-25-2008 "Standard Marking System for Valves, Fittings, Flanges, and Unions" Прикрепленный файл  MSS_SP_25_2008.pdf ( 324,85 килобайт ) Кол-во скачиваний: 189
MSS SP-75-2004 "Specification for High-Test, Wrought, Butt-Welding Fittings" Прикрепленный файл  MSS_SP_75_2004.pdf ( 2,29 мегабайт ) Кол-во скачиваний: 145
Dobriy-kot
сообщение 28.6.2016, 9:52
Пользователь №: 135047
MSS SP-25-2013
MSS SP-75-2014
Прикрепленный файл  MSS_SP_25_2013.pdf ( 1,33 мегабайт ) Кол-во скачиваний: 242
Прикрепленный файл  MSS_SP_75_2014.pdf ( 2,35 мегабайт ) Кол-во скачиваний: 235
Прикрепленный файл  MSS_SP_75_2014_main_changes_.pdf ( 591,4 килобайт ) Кол-во скачиваний: 172
4444qqqq
сообщение 27.7.2016, 13:37
Пользователь №: 276151
Коллеги, может найдется у кого-нибудь русскоязычный вариант MSS SP-55 Quality Standard for Steel Castings for Valves, Flanges, Fittings, and Other Piping Components. Visual Method for Evaluation of Surface Irregularities?
Сообщение отредактировал 4444qqqq - 27.7.2016, 13:39
Прикрепленный файл  MSS_SP_55_2001_VT_fo_Steel_Castings.pdf ( 13,29 мегабайт ) Кол-во скачиваний: 197
4444qqqq
сообщение 27.7.2016, 15:39
Нашел, но за перевод не уверен.
Прикрепленный файл  MSS_SP_55_2001_VT_fo_Steel_Castings_ru.pdf ( 3,72 мегабайт ) Кол-во скачиваний: 215
snti
сообщение 27.7.2016, 21:31
Из: Пермь
Пользователь №: 18280
оригинал посвежее
Прикрепленный файл  MSS_SP_55_2011.pdf ( 7,91 мегабайт ) Кол-во скачиваний: 229
99xt1
сообщение 30.9.2016, 16:03
Пользователь №: 83466
Господа, может у кого есть MSS SP-97 ?
DenissPek
сообщение 30.9.2016, 16:53
Из: Tallinn
не знаю, как у господ, а у меня есть такой:
MSS SP 97-2006 "Integrally Reinforced Forged Branch Outlet Fittings – Socket Welding, Threaded, and Buttwelding Ends" Прикрепленный файл  MSS_SP_97_2006.pdf ( 205,72 килобайт ) Кол-во скачиваний: 210
Dobriy-kot
сообщение 30.9.2016, 20:34
версия новее
Прикрепленный файл  MSS_SP_97_2012.pdf ( 309,15 килобайт ) Кол-во скачиваний: 294
99xt1
сообщение 5.10.2016, 16:44
Всем спасибо
baraxolka
сообщение 17.10.2016, 12:14
Пользователь №: 282106
Здравствуйте. Помогите найти стандарт MSS-SP 95.
moorch
сообщение 17.10.2016, 14:13
Прикрепленный файл  MSS_SP_95_2006_Swage_d_Nipples_and_Bull_Plugs.pdf ( 667,38 килобайт ) Кол-во скачиваний: 222
Serg111
сообщение 16.1.2017, 22:28
Пользователь №: 313150
Помогите пож-та найти MSS SP-99 и DIN EN 61518.
DenissPek
сообщение 17.1.2017, 10:30
Из: Tallinn
о! кстати о MSS
вроде этого тут не было:
MSS SP-832-1992 "Valve Pressure Testing Methods" Прикрепленный файл  MSS_SP_82_1992.pdf ( 344,17 килобайт ) Кол-во скачиваний: 131
Shuburshun
сообщение 17.1.2017, 12:17
Пользователь №: 132333
Прикрепленный файл  MSS_SP_99_2010_Instrument_Valves.pdf ( 285,15 килобайт ) Кол-во скачиваний: 163
Прикрепленный файл  DIN_EN_61518__2002_06.pdf ( 498,24 килобайт ) Кол-во скачиваний: 131
Serg111
сообщение 19.1.2017, 10:17
Премного благодарен!!!
Break-BoY
сообщение 7.3.2017, 10:49
Пользователь №: 316787
Всем спасибо!
DenissPek
сообщение 7.3.2017, 15:37
Из: Tallinn
MSS SP-53-2002 "Quality Standart for Steel Castings and Forging for Valves, Flanges, and Fittings and other Piping Components | Magnetic Particle Examination Method" Прикрепленный файл  MSS_SP_53_2002.pdf ( 314,7 килобайт ) Кол-во скачиваний: 109
MSS SP-100-2002 "Qualification Requirements for Elastomer Diaphragms for Nuclear Service" Прикрепленный файл  MSS_SP_100_2002.pdf ( 700,04 килобайт ) Кол-во скачиваний: 111
MSS SP-101-2001 "Part-Turn Vsalve Actuator Attachment Flange and Driving Component Dimensions and Performance Characteristics" Прикрепленный файл  MSS_SP_101_2001.pdf ( 261,71 килобайт ) Кол-во скачиваний: 115
MSS SP-106-2003 "Cast Copper Alloy Flanges and Fittings Class 125, 150, and 300" Прикрепленный файл  MSS_SP_106_2003.pdf ( 640,82 килобайт ) Кол-во скачиваний: 107
MSS SP-127-2001 "Bracing For Piping Systems Seismic - Wind -Dynamic Design, Selection, Application" Прикрепленный файл  MSS_SP_127_2001.pdf ( 3,24 мегабайт ) Кол-во скачиваний: 123
DenissPek
сообщение 7.3.2017, 17:11
Из: Tallinn
MSS SP-53-2012 "Quality Standart for Steel Castings and Forging for Valves, Flanges, and Fittings and other Piping Components | Magnetic Particle Examination Method" Прикрепленный файл  MSS_SP_53_2012.pdf ( 191,1 килобайт ) Кол-во скачиваний: 138
DenissPek
сообщение 15.3.2017, 13:30
Из: Tallinn
MSS SP-89-1998 "Pipe Hangers and Supports Fabrication and Installation Practices" Прикрепленный файл  MSS_SP_89_1998.pdf ( 1,01 мегабайт ) Кол-во скачиваний: 120
MSS SP-91-1996 "Guidelines for Manual Operation of Valves" Прикрепленный файл  MSS_SP_91_1996.pdf ( 486,57 килобайт ) Кол-во скачиваний: 126
DenissPek
сообщение 15.3.2017, 15:09
Из: Tallinn
MSS SP-43-2013 "Wrought and Fabricated Butt-Welding Fittings for Low Pressure, Corrosion Resistant Applications" Прикрепленный файл  MSS_SP_43_2013.pdf ( 746,93 килобайт ) Кол-во скачиваний: 117
MSS SP-89-2003 "Pipe Hangers and Supports Fabrication and Installation Practices" Прикрепленный файл  MSS_SP_89_2003.pdf ( 1,55 мегабайт ) Кол-во скачиваний: 132
MSS SP-75-2014 "Specification for High-Test, Wrought, Butt-Welding Fittings" Прикрепленный файл  MSS_SP_75_2014.pdf ( 2,93 мегабайт ) Кол-во скачиваний: 115
DenissPek
сообщение 26.7.2017, 11:28
Из: Tallinn
А не появилось ли у кого MSS SP 6-2017 ?
DenissPek
сообщение 13.8.2018, 14:27
Из: Tallinn
Кажется кто-то тут просил... правда старенький, но сойдет для сельской местности:
MSS SP-9-2001 "Spot Facing For Bronze, Iron and Steel Flanges" Прикрепленный файл  MSS_SP_9_2001.pdf ( 254,61 килобайт ) Кол-во скачиваний: 72
Dobriy-kot
сообщение 13.8.2018, 16:42
Есть посвежее
Прикрепленный файл  MSS_SP_9_2013.pdf ( 1,27 мегабайт ) Кол-во скачиваний: 94
3 страниц V   1 2 3 >
RSS Текстовая версия Сейчас: 17.5.2026, 13:33
