2 страниц V  < 1 2
> Пожаротушение встроенной стоянки с двухуровневым хранением автомобилей
BTS
сообщение 26.8.2017, 16:27
Пользователь №: 39493
Цитата(Sindarkon @ 26.8.2017, 14:36) *
В NFPA 13 и EN 12845 действительно нет, зато есть у FM Global:
FMDS 2-0
2.1.3.1.3 Mixing of Different Types of Sprinklers
Do not mix the following types of sprinklers on the same sprinkler system protecting the same hazard area unless otherwise recommended in the relevant occupancy-specific data sheet:
(a) Storage, Nonstorage, and Special Protection sprinklers
(d) Sprinklers having different K-factors
© Sprinklers having different orientation
(d) Sprinklers having different nominal temperature ratings
(e) Sprinklers having different nominal RTI values
(f) Sprinklers having different linear and/or area spacing requirements (e.g., extended-coverage and non-extended-coverage sprinklers)
Запрет не очень жёсткий.
В том же пункте есть исключения :
Exception No. 1: Install individual sprinklers having a higher temperature rating as needed based on ambient
temperature conditions (such as near unit heater outlets). Ensure the higher-temperature sprinklers are of
the same make, model, type, K-Factor, RTI, and orientation as the lower-temperature sprinklers.
Exception No. 2: An upright sprinkler may be substituted for an obstructed pendent sprinkler provided it
has the same K-factor, nominal temperature rating, nominal RTI, and recommended sprinkler spacing as the
pendent sprinkler and is compatible for the occupancy hazard.
Exception No. 3: Sprinklers installed under lower ceilings are not considered ”on the same system.” See
recommendations in Section 2.1.1.4 if the lower ceiling is open-grid, or Section 2.1.1.5 if the lower ceiling is
solid.
Exception No. 4: When two different occupancy hazards are adjacent to each other and are not separated
by a wall or draft curtain, extend the design of the sprinkler system protecting the higher-hazard occupancy
a minimum of 20 ft (6.0 m) in all directions beyond the perimeter of the higher-hazard occupancy area.
В разделе 2.3.3 описаны варианты совместной установки вертикальных и настенных спринклеров.
Сообщение отредактировал BTS - 26.8.2017, 16:37
Sindarkon
сообщение 26.8.2017, 17:08
Из: Питера
Пользователь №: 13769
Так о чём и речь: есть запрет, и есть исключения. А в СП5 только запреты.
Prologue
сообщение 11.9.2017, 18:54
Пользователь №: 324390
Коллеги, добрый вечер
Решаю аналогичную задачу - тушение мех. парковки с KLAUS.
Получается помещение парковки у нас одна интенсивность и расход для сплинкерной системы, а местах установки двухярусных агрегатов 2-й расход и сложносочиненная интенсивность.
Какие формулировки применяли в СТУ для защиты технологических решений?
Буду благодарен за опыт, мысли, идеи.
Спасибо.
jiexawcr
сообщение 18.9.2017, 11:22
Сообщение #34
Из: Ленинграда
Пользователь №: 291398
тут правильнее для понимания СП 5.13130.2009 п. 5.2.15, так как подъемники (технологическое оборудование) с площадками шириной свыше 0,75м и высотой свыше 0,7м. "...следует дополнительно
под эти площадки установить спринклерные оросители или распылители". Интенсивность должна быть нормативной на каждой площадке (?).
Вопрос в том, что площадки подвижные и прям под них не установишь.
Sindarkon
сообщение 18.9.2017, 21:58
Сообщение #35
Из: Питера
А как вы сами собираетесь защищать технологические решения?
Сообщение отредактировал Sindarkon - 18.9.2017, 21:59
israilovsib
сообщение 18.10.2017, 13:24
Сообщение #36
Из: москва
Пользователь №: 117047
Уважаемые коллеги, применял ли кто-либо на системе АПТ устройство принудительного пуска УПП Старт-3 от "ПО Спецавтоматика" для запуска нижнего яруса спринклеров при двухуровневом хранении автомобилей в автостоянке?
komdiv
сообщение 11.4.2025, 9:17
Сообщение #37
Пользователь №: 17160
Цитата(jiexawcr @ 18.8.2017, 14:23) *
По принудительному пуску - явное удорожание. Я занимаюсь "переделкой" готовых проектов до рабочего состояния и сдаваемого состояния с урезанием лишнего и дорогого, то принудительный пуск - нарушение принципов работы dry.gif хотя конечно идет в разрез с инженерной логикой.
Очень интересно, как рассчитывать расход воды, если не применять принудительный пуск? В СТО 420541.005 Гефест для полумеханизированных двухуровневых парковок в примере приведена схема: 3+3 авто (6+6 спринклеров). Но без принудительного пуска надо будет считать по нормированной площади АУП (120/90 кв.м) со всеми спринклерами, попадающими в эту зону в обоих уровнях. А это может и более чем в 2 раза потребовать увеличение воды, что не всякий водопровод выдержит даже для ТРВ-НД. Насколько "легко" можно "переделать" проект, выкинув из него принудительный пуск?
2 страниц V  < 1 2
RSS Текстовая версия Сейчас: 4.4.2026, 2:58
