> Xworks 6.0, Element type
Troyan_Yura
сообщение 13.7.2017, 8:26
Пользователь №: 324785
Добрый день.
Нигде не могу найти описание по Element Type Chart.
Chart можно задать определенным типом: агрегат, глобальная область, динамическая область, дополнительный элемент, комната, компонент, область, подобласть, секция, системная область, установка, часть установки.
так вот я так понимаю у этих типов определенная иерархия... Где можно почитать эту иерархию?
Сообщение отредактировал Troyan_Yura - 13.7.2017, 8:27
Sigezmund
сообщение 13.7.2017, 12:14
Пользователь №: 134796
В Help не смотрели?
The elements in the CFC charts are hierarchically structured. We differentiate between hierarchy elements and function elements.
Hierarchy and function elements
Hierarchy elements:
Plant
Area
Subarea
Section
Auxiliary element
Function elements:
Partial plant
Aggregate
Component
Room
Auxiliary element
Note: As opposed to the hierarchy elements, the function elements with the exception of auxiliary elements have a main value. This value is displayed upon operation with the PXM20.
Rules for structuring a hierarchy
Hierarchical order for hierarchy elements (> means higher)
Top chart area (created in the XWORKS Manager) > plant > partial plant > section.
or
Top chart plant (created in the XWORKS Manager) > area > partial plant > section.
You can also skip hierarchy elements.
Hierarchical order for function elements (> means higher)
Any hierarchy element > partial plant > room > aggregate > component.
Aggregates can be inserted in aggregates.
Components can be inserted in components.
You can also skip function elements.
Further elements used for structure
Auxiliary elements can be used freely anywhere in the hierarchy.
Hierarchy elements can be used anywhere in the hierarchy by adhering to the permissible order.
Important: The total number of hierarchies may not exceed 7.
Examples
Top chart > component (when working in XWORKS featuring a standard structure).
Top chart area > plant > auxiliary element > aggregate.
Top chart plant > section > area > aggregate > aggregate > component.
Top chart area > room > component.
Top chart plant > partial plant > auxiliary element > aggregate > component > component.
Troyan_Yura
сообщение 13.7.2017, 12:32
Спасибо, не нашел в Help данного описания!!!
теперь хоть стало понятно, что к чему!
не совсем понял! тут имеется ввиду что нельзя в иерархическом дереве сделать больше 7 ответвлений или нельзя вообще больше 7 chart делать в любом ответвлении?
Sigezmund
сообщение 13.7.2017, 12:46
Затрудняюсь ответить. Часто пользуюсь всеми типами чартов, проблем никогда не возникало.
Djon_79
сообщение 18.7.2017, 21:57
Пользователь №: 254728
У чатов есть своя иерархия. Нельзя поместить чат более высокого уровня в чат более низкого. На счёт 7 ответвлений не очень понял что Вы имели в виду. Сейчас лень проверять, но скорее всего в описании речь шла что нельзя сделать более семи вложений (чат в чате).
Emelyanovich
сообщение 19.7.2017, 8:23
Пользователь №: 150894
Не более семи уровней чартов, при добавлении восьмого чарта CFC Editor ругнется и не даст его создать или при компиляции выпадет ошибка.
RSS Текстовая версия Сейчас: 25.12.2025, 5:51
