Desigo Insight V4.1 |
16.4.2019, 11:39
Пользователь №: 358993
hello
im from iran. i find your forum in google. i install desigo insight v4.1 . but i dont have license. i just want learn.please help me run it. i dont have license.help
Сообщение отредактировал awi - 16.4.2019, 11:41
22.4.2019, 7:41
Из: Новосибирск
Пользователь №: 17138
Цитата(awi @ 16.4.2019, 15:39)  hello
im from iran. i find your forum in google. i install desigo insight v4.1 . but i dont have license. i just want learn.please help me run it. i dont have license.help In this issue you will help Allah, or the official representative of Siemens
3.5.2019, 23:09
Цитата(alsz @ 22.4.2019, 7:41)  In this issue you will help Allah, or the official representative of Siemens yes allah help me i install it now!with emulator+ license i have xwork too! now i have another question! can i create virtual project?how can run simulation?i dont have real controller for test.
7.5.2019, 21:28
Пользователь №: 254728
1. create a project for the PXC100D controller. 2. write a test program with no errors in compile 3. after successful compilation, select one of the lower menu items (I do not remember exactly the menu section) StartAS Simulator. 4. the simulator starts. In the development environment, select the download and choose SIM (simulator) as the communication interface. 5. Connect on-line to the simulator and selecting blocks click on the symbol points for view 6. change the parameters in the simulator. See changes in the program
He wrote through an automatic translator. I did not delve deeply into the translation. If something is unclear, then write, ask.
10.5.2019, 17:47
Цитата(Djon_79 @ 7.5.2019, 22:28)  1. create a project for the PXC100D controller. 2. write a test program with no errors in compile 3. after successful compilation, select one of the lower menu items (I do not remember exactly the menu section) StartAS Simulator. 4. the simulator starts. In the development environment, select the download and choose SIM (simulator) as the communication interface. 5. Connect on-line to the simulator and selecting blocks click on the symbol points for view 6. change the parameters in the simulator. See changes in the program
He wrote through an automatic translator. I did not delve deeply into the translation. If something is unclear, then write, ask. thanks for help i have error when i click startas simulator  after i click download i have this error
Сообщение отредактировал awi - 10.5.2019, 17:50
12.5.2019, 11:40
Did you create a network in Network Configurator? Is the controller on any network?
12.5.2019, 18:05
Цитата(Djon_79 @ 12.5.2019, 11:40)  Did you create a network in Network Configurator? Is the controller on any network? No
14.5.2019, 23:55
Цитата(Djon_79 @ 12.5.2019, 11:40)  Did you create a network in Network Configurator? Is the controller on any network? Can i run without controller?or must connect to real control all the time for test?
Сообщение отредактировал awi - 14.5.2019, 23:56
15.5.2019, 7:18
Цитата(awi @ 14.5.2019, 23:55)  Can i run without controller?or must connect to real control all the time for test? Yes, you can. The meaning of the simulator is to run a program for debugging without a real controller. I will soon make you screenshots to run the simulator.
23.5.2019, 22:05
screenshots after compilation without errors and then run the simulator During loading, the sequence of images could be moved. Sequence in file names. If it is not clear, I can sign them.
28.5.2019, 11:14
Цитата(Djon_79 @ 23.5.2019, 22:05)  screenshots after compilation without errors and then run the simulator
During loading, the sequence of images could be moved. Sequence in file names. If it is not clear, I can sign them. thank you
4.10.2022, 18:01
Пользователь №: 381947
Всем привет. Ситуация обратная. Есть ключ от desigo insight v4.1. Но нет сейчас возможности достать дистрибутив. Кто сможет помочь? Ситуация простая, стояла скада, комп помер. Нужно сделать заново, в сименс сейчас писать/звонить бесполезно...
4.2.2023, 15:56
Пользователь №: 77347
9.4.2025, 9:07
Пользователь №: 441546
Цитата(Rapid @ 4.2.2023, 16:56)  Мне тоже нужен этот дистрибутив. По ссылке он удалён. Скиньте снова, пожалуйста!
6.4.2026, 13:59
Пользователь №: 452150
Присоединюсь к просьбе, выложите пожалуйста, если у кого осталось.
