Стандарты ВS, ВS EN ..., Подборка |
12.6.2020, 2:21
Из: egypt
Пользователь №: 344143
Цитата(snti @ 11.6.2020, 6:31)  the requested EN 14216 not found there are a lot of standards not found in the link please check
12.6.2020, 2:38
Из: Everywhere
Пользователь №: 363778
QUOTE (ahmedadel @ 12.6.2020, 1:21)  the requested EN 14216 not found there are a lot of standards not found in the link please check
15.6.2020, 11:56
Пользователь №: 377069
BS EN ISO 13680:2020 Petroleum and natural gas industries. Corrosion-resistant alloy seamless tubular products for use as casing, tubing, coupling stock and accessory material. Technical delivery conditions
wanted... please share here.
thank you in advance!
Сообщение отредактировал enrike bora - 15.6.2020, 11:57
18.6.2020, 11:52
Из: Баку
Пользователь №: 346898
Цитата(enrike bora @ 15.6.2020, 12:56)  BS EN ISO 13680:2020 Petroleum and natural gas industries. Corrosion-resistant alloy seamless tubular products for use as casing, tubing, coupling stock and accessory material. Technical delivery conditions
thank you in advance! https://drive.google.com/file/d/1F-DqXIoOWb...iew?usp=sharing
Гость_Peterlov_*
18.6.2020, 13:06
Цитата(eldar1976ndt @ 18.6.2020, 11:52)  Hi eldar1976ndt, Thanks for your unselfish contribution. Unfortunately, I can not open google drive at this stage, would you like to share BS EN ISO 13680:2020 IN OTHER WAY? Please help me. Best Regards
18.6.2020, 13:11
Из: Баку
Цитата(Peterlov @ 18.6.2020, 14:06)  Hi eldar1976ndt, Thanks for your unselfish contribution. Unfortunately, I can not open google drive at this stage, would you like to share BS EN ISO 13680:2020 IN OTHER WAY? Please help me. Best Regards write your mail,или пишите в личку. урезали админы лимит на загрузку 1-го фаила (до 2 мб),поэтому не могу загружать сюда многие фаилы.
Сообщение отредактировал eldar1976ndt - 18.6.2020, 13:17
Гость_Peterlov_*
18.6.2020, 13:26
Цитата(eldar1976ndt @ 18.6.2020, 13:11)  write your mail,или пишите в личку.
урезали админы лимит на загрузку 1-го фаила (до 2 мб),поэтому не могу загружать сюда многие фаилы. Hi eldar1976ndt, Thanks for your prompt response. Please send the document to following address: fengchuntao1971888@gmail.com Much obliged for your help. Best Regards
27.6.2020, 22:42
Пользователь №: 376603
Всем привет! Помогите найти эти два стандарта. BS EN 13445-2-2014+A3-2018  BS EN 13445-1-2014 + A2-2018 Заранее спасибо.
28.6.2020, 8:43
Из: Пермь
Пользователь №: 18280
Цитата(Женя Петров @ 28.6.2020, 0:42)  Всем привет! Помогите найти эти два стандарта. BS EN 13445-2-2014+A3-2018  BS EN 13445-1-2014 + A2-2018 Заранее спасибо. читайте http://forum.abok.ru/index.php?showtopic=7...t&p=1505328и скачивайте
28.6.2020, 10:40
Цитата(snti @ 28.6.2020, 9:43)  Большое спасибо!
9.7.2020, 19:28
Всем привет!
ищу вот это BS EN ISO 11114-1-2020 Gas cylinders. Compatibility of cylinder and valve materials with gas contents. Metallic materials
9.7.2020, 20:38
Из: Баку
Цитата(Женя Петров @ 9.7.2020, 20:28)  Всем привет!
ищу вот это BS EN ISO 11114-1-2020 Gas cylinders. Compatibility of cylinder and valve materials with gas contents. Metallic materials Держите!
10.7.2020, 13:46
Цитата(eldar1976ndt @ 9.7.2020, 21:38)  Держите! Спасибо тысячу раз!)))
18.7.2020, 0:01
Из: egypt
Hi Dears
please help me in finding these standards
BS EN 196-1-2016 BS EN 196-10-2016 BS EN 196-11-2018 BS EN 196-3-2016 BS EN 196-6-2018 BS EN 197-2-2020
thanks in advance
18.7.2020, 18:13
ищу, вот этот стандарт, в 2-x частях!
помогите найти! Спасибо!
BS EN 13598(1,2)-2020
19.7.2020, 1:06
Из: Баку
Цитата(Женя Петров @ 18.7.2020, 19:13)  ищу, вот этот стандарт, в 2-x частях!
19.7.2020, 6:21
Из: egypt
thanks in advance can anyone help ???
19.7.2020, 21:22
Из: egypt
thanks in advance пожалуйста, помогите срочно
20.7.2020, 10:13
Пользователь №: 363564
Цитата(ahmedadel @ 19.7.2020, 7:21)  can anyone help ??? in PM
20.7.2020, 13:21
Цитата(eldar1976ndt @ 19.7.2020, 2:06)  Спасибо!
20.7.2020, 22:41
Пользователь №: 282801
Добрый день всем Если кто-то может, пожалуйста, поделитесь  BS EN IEC 63132-1:2020 BS EN IEC 63132-2:2020 BS EN IEC 63132-3:2020 BS EN IEC 63132-4:2020 ISO 7902-1:2020 ISO 7902-2:2020 ISO 7902-3:2020 ISO 12130-2:2020 ISO 12130-3:2020 ISO 12131-1:2020 ISO 12131-3:2020 ISO 12168-1:2019 ISO 12168-2:2019 ISO/TS 31657-1:2020 ISO/TS 31657-2:2020 ISO/TS 31657-3:2020 ISO/TS 31657-4:2020 Заранее огромное, спасибо
21.7.2020, 0:26
Из: egypt
Цитата(Wertu @ 20.7.2020, 9:13)  in PM Dear Thanks, but 196-1, 196-10, 196-3 are not found
21.7.2020, 1:30
Из: Баку
Цитата(ahmedadel @ 21.7.2020, 1:26)  Dear Thanks, but 196-1, 196-10, 196-3 are not found
21.7.2020, 1:59
Из: egypt
Цитата(eldar1976ndt @ 21.7.2020, 0:30)  Thanks a lot
21.7.2020, 8:19
Цитата(trilala456Trilala @ 20.7.2020, 23:41)  Добрый день всем Если кто-то может, пожалуйста, поделитесь  BS EN IEC 63132-1:2020 BS EN IEC 63132-2:2020 BS EN IEC 63132-3:2020 BS EN IEC 63132-4:2020 ISO 7902-1:2020 ISO 7902-2:2020 ISO 7902-3:2020 ISO 12130-2:2020 ISO 12130-3:2020 ISO 12131-1:2020 ISO 12131-3:2020 ISO 12168-1:2019 ISO 12168-2:2019 ISO/TS 31657-1:2020 ISO/TS 31657-2:2020 ISO/TS 31657-3:2020 ISO/TS 31657-4:2020 Заранее огромное, спасибо Всё это есть у китайцев Посетить
30.7.2020, 1:18
Ищу !
BS EN ISO 25239(1-5) части 2020 года.
Friction stir welding. Aluminium
BS EN IEC 60974-1:2018+A1:2019. Arc welding equipment. Welding power sources
заранее спасибо!
Сообщение отредактировал Женя Петров - 30.7.2020, 1:23
31.7.2020, 1:05
Из: Баку
заранее спасибо!
Сообщение отредактировал eldar1976ndt - 31.7.2020, 1:06
2.8.2020, 22:09
Цитата(eldar1976ndt @ 31.7.2020, 2:05)  Спасибо!!!
8.9.2020, 13:21
Пользователь №: 222231
Дорогие коллеги, помогите найти, пожалуйста, следующие стандарты: ISO 17672:2016 Brazing - Filler metals EN 13134:2000 Brazing. Procedure approval ISO 13585:2012 Brazing - Qualification test of brazers and brazing operators Заранее благодарна!
9.9.2020, 12:23
Из: Баку
Цитата(nadinn83 @ 8.9.2020, 14:21)  Дорогие коллеги, помогите найти, пожалуйста, следующие стандарты: ISO 17672:2016 Brazing - Filler metals EN 13134:2000 Brazing. Procedure approval ISO 13585:2012 Brazing - Qualification test of brazers and brazing operators Заранее благодарна!
6 чел. читают эту тему (гостей: 6, скрытых пользователей: 0)
