Полная версия этой страницы: Стандарты API...
Диалог специалистов АВОК > ФАЙЛОТЕКА СПЕЦИАЛИСТА > Нормативные документы
Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11
pushkarev
Документ Inspection of Fired Boilers and Heaters, Draft 3-rd Ed., 2010 выложен для свободного ознакомления здесь:
http://www.docin.com/p-589839449.html
faritch
только на английском
moorch
API Std 520, Part 1
Sizing, Selection, and Installation of Pressure-Relieving Devices in Refineries—Part 1, Sizing and Selection
API Std 521/ISO 23251:2006
Guide for Pressure-Relieving and Depressuring Systems (includes Errata 1 dated June 2007 and Addendum 1 dated May 2008)
Не совсем свежий, уже есть редакция № 26, 2011 г.
API Spec 9A
Specification for Wire Rope
Twenty-fifth Edition, February 2004
moorch
Цитата(ulyan0v @ 13.2.2013, 22:05) *
Ищу:
- API 620,
- API-1104,
- API 598,
- API Spec 5L,
- API 650,
- API RP 582,
- API Spec 12D.
В идеале на русском и в pdf. Заранее спасибо!
API RP 582 Recommended Practice Welding Guidelines for the Chemical, Oil, and Gas Industries, 1st Edition, 2001
API Std 598 (R2009) Valve Inspection and Testing
API Std 620 Design and Construction of Large, Welded, Low-Pressure Storage Tanks, 11th Edition, Includes Addendum 1 (2009), Addendum 2 (2010), and Addendum 3 (2012)
API Std 650 Welded Tanks for Oil Storage, 11th Edition, Includes Addendum 1 (2008), Addendum 2 (2009), Addendum 3 (2011), Errata (October 2011)
API Std 1104 (R2010) Welding of Pipelines and Related Facilities - 20th Edition, Includes Errata 1 (2007) and 2 (2008)
ANSI/API Spec 5L Specification for Line Pipe, 44th Edition, Includes Errata and Addendums 1 (2009), 2 (2010), and 3 (2011)
API Spec 12D Specification for Field Welded Tanks for Storage of Production Liquids, 10th Edition, 1994
moorch
Barsuk
А вот действующее второе издание API 684, подтвержденное в 2010 году (2nd Edition, August 2005, Reaffirmed: November 2010)
svetlanaL
Каталог API 2013 г.
См. стр. 166 и далее.
DAYN
Цитата(svetlanaL @ 10.4.2013, 23:14) *
Каталог API 2013 г.
Спасибо.
moorch
API RP 752
Management of Hazards Associated with Location of Process Plant Buildings
3rd Edition, December 2009
moorch
Цитата(-sever- @ 17.5.2013, 18:05) *
Люди добрые а не у кого нет 650 или 620 стандарта на русском языке?
Только старое-старое издение
yergat
API 620 2002 н арусском
SteelRatCrazy
Ищу:
API Specification 6H, 2-е издание Спецификация на концевые быстрооткрывающиеся затворы, компенсаторы и шарнирные соединения
И еще:
ANSI/API Specification 5L-2008 Техусловия для труб для трубопроводов. Нефтегазовая промышленность – Трубы стальные для трубопроводных транспортных систем
Кто чем может помочь?
Shuburshun
Лови. Тут всё это уже всплывало. Только вот API 5L объявлен уже от 2013
moorch
API Spec 6H
Specification on End Closures, Connectors, and Swivels
2nd Edition, May 1998
WITHDRAWN (ОТМЕНЕН без замены) IN 2012
svetlanaL
API spec 5L-2013
Shuburshun
Стандарт
moorch
API Spec 16A/ISO 13533:2001
Specification for Drill-Through Equipment
(includes Supplement/Errata 1 dated November 2004)
3rd Edition. June 2004. Effective Date: December 1, 2004
API Spec 16C
Choke and Kill Systems
1st Edition. January 1993
API RP 53
Blowout Prevention Equipment Systems for Drilling Operations
3rd Edition. March 1997
Заменены в 2012 на API Std 53
moorch
Цитата(VJik @ 6.8.2013, 9:22) *
Ну очень нужен API SPEC 5L русскоязычный.
Раз нет времени, то и читай ГОСТ Р ИСО 3183-2009, который какбэ идентичен 44 изданию API Spec 5L
svetlanaL
У меня есть только 2004 г.
moorch
API RP 534
Heat Recovery Steam Generators
1st Edition, January 1995
недействующий, ищется актуальная редакция
API Std 611
General Purpose Steam Turbines for Petroleum, Chemical, and Gas Industry Services
4th Edition, June 1997
API Std 612/ISO 10437:2003
Petroleum Petrochemical and Natural Gas Industries—Steam Turbines—Special-Purpose Applications
6th Edition, November 2005
API Std 671/ISO 10441:2007
Special Purpose Couplings for Petroleum, Chemical and Gas Industry Services
4th Edition, August 2007
API Std 674
Positive Displacement Pumps—Reciprocating
3rd Edition, December 2010
API Std 676
Positive Displacement Pumps—Rotary
3rd Edition, November 2009
kvl_red
API Std 611 есть вот такой:
moorch
азыскивается API SPEC 5CRA-2010
Очень разыскивается. Если есть старые издания, то они тоже будут приняты с благодарностью
API SPEC 5CRA-2010 какбэ идентичен ISO 13680:2010
А у нас скоро издадут
ГОСТ Р ИСО 13680-2011 Трубы бесшовные обсадные, насосно-компрессорные и трубные заготовки для муфт из коррозионно-стойких высоколегированных сталей и сплавов для нефтяной и газовой промышленности. Технические условия
Есть пока только проект
moorch
Поправка: есть не проект а уже официальная версия
ISO 13680:2010
Petroleum and natural gas industries — Corrosion-resistant alloy seamless tubes for use as casing, tubing and coupling stock — Technical delivery conditions
(IDT)
Kostrov
Уважаемые коллеги, помогите найти API 572 и API 510 в русском переводе, буду очень признателен!
moorch
API Spec 7-1/ISO 10424-1:2004
Specification for Rotary Drill Stem Elements
(includes Addendum 1 dated March 2007, Addendum 2 dated August 2009, and Addendum 3 dated April 2011)
Covers the following products:
• upper and lower kelly valves,
• square and hexagon kellys,
• drill-stem subs,
• drill collars, and
• drilling and coring bits.
Rotary shouldered connections and gauging for drill stem elements are covered in Spec 7-2.
This edition of Spec 7-1 is the modified national adoption of ISO 10424-1:2004. Pages: 87
1st Edition, February 2006. Effective Date: September 1, 2006
svetlanaL
API 614
nalekhina
Цитата(Thomas0202 @ 25.12.2013, 9:45) *
коллеги, помогите найти полный перевод на русский API 620, буду очень признателен!
У меня есть только старый есть:
svetlanaL
Разыскивается API SPEC 5DP и Разыскивается API SPEC 5CT желательно и очень хочется на русском языке. Заранее спасибо.
http://www.fayloobmennik.net/3487726
http://www.fayloobmennik.net/3487730
Shuburshun
Цитата(saxa35 @ 20.1.2014, 21:38) *
Спасибо большое за 5CT, вот бы еще 5D найти!
Добрый я очень по понедельникам
Shuburshun
А если тебе 5DP, то учти, что он эквивалентен ISO 11961, которому эквивалентен ГОСТ Р 54383-2011
Ну а если уж принципиально нуже APi, то сегодня явно не пятница (по пятницам я, как и ОИСМББ, не подаю huh.gif )
moorch
API Spec 5L, 44 издание (заменено на 45)
На русском
lla
Всем Доброго времени суток.
Перекопал кучу ссылок не ни где не могу найти. Постоянно натыкаюсь на оригинал.
Ну или ссылочку дайте может кто встречал. Оригиналом пользоваться нет времени, очень сжатые сроки.
eto 44 s dopolneniami
magdolina
Помогите, нужны стандарты API Spec 8A, API Spec 8C и API Spec 7K
с переводом есть 2003 года ))))
svetlanaL
Господа, поделитесь, пож-та, если есть возможность, русским вариантом API Std 611 General-purpose steam turbine, особо нуждаюсь в форме листа тех.данных!!! Спасибо!!
http://www.api.org/~/media/Files/Publicati...nal-catalog.pdf
См. стр. 174
alim_uralsk
Закинул полный аналог API 610 - ISO 13709-2004 на казахском и русском последняя версия 2004г.
Dobriy-kot
Держите API 685 2-я
moorch
API RP 5L2
Recommended Practice for Internal Coating of Line Pipe for Non-Corrosive Gas Transmission Service
4th Edition, July 2002
alim_uralsk
Цитата(Ale55a @ 13.10.2014, 8:03) *
Добрый день всем! Очень нужен стандарт API 610 (11 редакция) на русском. Помогите, пожалуйста.
Есть API 610 (9 редакция) т.еИСО13709:2003
snowbarsik
чот не совсем на русском
svetlanaL
См. со средины документа, там на русском.
DenissPek
Нажмите для просмотра прикрепленного файла API RP 934-E 1ed 2010 "Материал и изготовление стальных толстостенных сосудов марки 1 1/4Cr-1/2Mo, работающих под давлением, применяемых в водородной среде при высоком давлении и температуре ниже 825F (440C)" не ручаюсь за качество перевода....
DenissPek
ну и часть А тогда уж на русском тож Нажмите для просмотра прикрепленного файла
vova-vipper
API 6D 24-ая редакция:
http://www.twirpx.com/file/1580598/
DenissPek
держите API 6D 24-ую редакцию если надо
baur
кто может помогите срочно надо....желательно 2013 года выпуска ....заранее спасибо всем
Получите
acier58
Enjoy!
acier58
Enjoy!
acier58
Enjoy!
acier58
Цитата(magdolina @ 26.2.2015, 7:41) *
ищу API 521-2014, есть 2007 года
Here is the requested standard. Enjoy!
