Полная версия этой страницы: Выборы, выборы, кандидаты...?
Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506
Для тех, кто не из Москвы, чтоб понятнее посты про маразм с парковками.
По ссылкам фотоподборки.
http://zyalt.livejournal.com/482264.html
http://zyalt.livejournal.com/464989.html
http://zyalt.livejournal.com/469763.html
http://zyalt.livejournal.com/462174.html
Skaramush
Цитата(sonsumerek @ 26.2.2012, 22:36) *
я кажется рассказывала уже, но повторюсь:
Ну, если пропустить матерные комментарии, сказать нечего.
Но не уверен, что ничего нельзя сделать. Не вам, так как определённый расчёт на недееспособность послеродовую тут может быть. А вот последовательно, с ответами "снизу" поднять пласт доверху может оказаться реальным.
Но вот если всё будет заканчиваться только возмущением на форумах, без резонанса - так оно и останется. Или будет конвертироваться "Навальными" в "Путин уходи".
sonsumerek
ага, такие есть в соседнем дворе )
Skaramush
Ну, мог бы не парковку, а разметку на центральных улицах показать. По которой (если следовать) должна у машины габаритная ширина уменьшаться по мере движения до мотоциклетной.
Везде хватает бардака и ой как не последнюю роль тут сыграли отмены единых стандартов и отмены ответственности за их нарушение.
sonsumerek
не то что "может быть", он тут по полной )), потом мне стало сильно не до этого, а потом тупо прошел срок давности...
ЁЖик
Здесь нет обратной связи.
_______________________________
Эх-х... да что ему говорить... скоро лично приедет НАВСЕГДА и всё поймёт...
Skaramush
Эх-х... да что ему говорить... скоро лично приедет и всё поймёт...
Как уже написал, гораздо проще и комфортнее поучать и писать про "всёпропалоибесполезно" на форумах.
ЁЖик
Так вот приедете, и покажи'те (уж) как надо делать дело дельное. Уж вразумите неразумных.
Вы ж щас тоже на форуме... поучаете... (и Вас даже не смущает, что поучаете - не находясь ЗДЕСЬ (не в командировке, а на ПМЖ здесь не находясь (ну вот не смущаетъ)))
Не так.
Стандарты на габариты парковочных мест не отменяли. Они действуют, как и вся градостроительная документация.
Президент назначил мэра, мэр дал указание префектурам, те управам на увеличение парковочных мест.
Парковочные места увеличили таким образом, отчитались на верх.
Потрачены бюджетные деньги налогоплательщиков.
Skaramush
Нет, я не поучаю. У меня несколько другая цель. Впрочем, вам она, похоже, понятна. Отсюда и реакция.
ЁЖик
Надеюсь, что она мне понятна. Потому и реакция такая. В менеджменте, реакционные практики - уже не в ходу. (где-то рядом, с alem обменялись о том ("следы обмена" правда стёрты)). Но, "не в ходу", не значит "отменены". А раз НЕ отменены, значит иногда эти практики надо применять. mellow.gif
Skaramush
Цитата(Vano @ 26.2.2012, 22:54) *
Не так.
До сих пор - ясно. Принимающая и надзирающая сторона - кто? Как понимаю, вплоть до прокуратуры.
То есть - на актах приёмки есть подписи. Самим нарушителям на них же жалоба бесполезна. То есть - или выше, или "в сторону".
Было такое, хоть по одной парковке?
Цитата(Skaramush @ 27.2.2012, 0:36) *
В том случае, если "наверху" искренне против решения - нерешаемо вообще ничего.
В противоположном - всё начинается с малого.
Нерешаемо бывает часто и если наверху за.
Пример.
Молодые папы с мамами, помнят как наверху озадачились очередью в детские сады, и дали поручение на возврат помещений детских садов, перепрофилированных в лихие 90-е.
Вот как происходит возврат в Москве.
При том что есть очередь, и есть льготная очередь - листков 8 формата А4 категорий внеочередников очень внеочередников и совсем внеочередников начинается с депутатов и работников прокуратуры по степени внеочередности.
Ниже переписка:
Тема: детский сад
Добрый день. Планируется ли в ближайшее время на территории варшавского шоссе близ дома №2,4,6,8,10 постройка детского сада? Ближайший детский сад № 651 находится прямо под 3-им кольцом, не особо бы хотелось чтобы ребенок там дышал газами. Остальные детские сады находятся далеко, надо ехать на транспорте. Многие мамы (в том числе и я )моего района недовольны садиком 651 и то что в нашем районе нет хорошего сада. (Раньше был около стадиона труд, сейчас там фитнес клуб). Есть ли возможность постройки детского садика? Что нужно для это сделать?
Ответ:
Ваше обращение от 16.11.2011г. № 67149 поступившее через интернет по вопросу постройки детского сада, рассмотрено.
В настоящее время прорабатывается вопрос о возврате нежилых помещений бывших детских садов по следующим адресам:
- Варшавское шоссе, д.10А;
- Варшавское шоссе, д.13;
- Варшавское шоссе, д.21.
После поступления положительного ответа по вышеуказанным адресам будут открыты дошкольные учреждения.
Добрый день. Прошу уточнить по поводу детского сада на Варшавском шоссе, д. 10А, чей должен быть положительный ответ и через сколько после положительного ответа откроется садик? http://don.uao.mos.ru/FeedBack/fbonequesti...uestionid=67149 C уважением, Софья
Ответ:
Ваше обращение от 13.12.2011г. № 67679 поступившее через интернет по вопросу открытия детского сада по адресу Варшавское ш., д.ЮА, рассмотрено.
В Департамент имущества города Москвы было направлено обращение по возврату бывшего детского сада №422 расположенного по адресу: Варшавское шоссе, д.ЮА.
После поступления положительного ответа от ДИГМ в течение 2-х лет будет открыто дошкольное учреждение по вышеуказанному адресу.
Глава управы Донского района СИ. Кузнецов
Добрый день. Вы написали, что в Департамент имущества города Москвы было направлено обращение по возврату бывшего детского сада №422 расположенного по адресу: Варшавское шоссе, д.ЮА. ЮА - это 10А? Прошу предоставить номер входящего обращения и дату поступления. Сколько дней оно будет рассматриваться в департаменте имущества? http://don.uao.mos.ru/feedback/fbonequesti...rid=0&sstr= С уважением, Софья.
Ответ:
Ваше обращение от 16.01.2012г. № 68145 поступившее через интернет по вопросу открытия детского сада по адресу Варшавское ш., д.ЮА, рассмотрено.
По информации ДИГМ нежилое помещение по адресу: Варшавское шоссе, д.ЮА сдано в аренду ООО «Даниловка».
Договор аренды с вышеуказанной фирмой пролонгирован до 2015 года.
В связи с вышеизложенным возврат ГОУ ДОУ №422 до окончания срока аренды не предоставляется возможным.
Добрый день. Планируется ли в ближайшее время на территории варшавского шоссе близ дома №2,4,6,8,10 постройка детского сада? Что делается по этому вопросу? Прошу ответить по поводу оставшихся вариантов? http://don.uao.mos.ru/feedback/fbonequesti...rid=0&sstr= С уважением, Софья.
Ответ:
Ваше обращение от 31.01.2012г. № 68445 поступившее через интернет по вопросу открытия детского сада. По информации ДИГМ:
- нежилое помещение по адресу: Варшавское шоссе, д.ЮА сдано в аренду ООО «Даниловка».
- нежилое помещение по адресу: Варшавское шоссе, д.21 сдано в аренду ЗАО «Старт-96», оборонно-спортивной орг. «РОСТО».
Договора аренды с вышеуказанными фирмами пролонгированы до 2015 года.
Нежилое помещение по адресу: Варшавское шоссе, д. 13 находится в частной собственности.
В связи с невысокой очередностью в детские дошкольные учреждения постройка ДОУ на территории района не планируется.
Информирую, что ближайшие детские учреждения расположены по следующим адресам:
- ГОУ ДОУ №2241 (Севастопольский пр-т, д.ЗА);
- ГОУ ДОУ №651 (ул. М.Тульская, Д.45А);
- ГОУ ДОУ №1588 (Загородное гл., д.6А, к.,6).
ЁЖик
Ну ФСЁ!!!
Скоро Skaramush в Рашу-чебурашу приедет. Все припаркуемся...
______________________________________________________________
Пока тут в йентой политике ... В рацухе, два человека посты свои оставили! У ВАС совесть есть, или где?!
Ушолъ в рацуху. (с Извинениями ушолъ)
"Они думают взять нас живыми. Дети!" ©
Skaramush
Цитата(ЁЖик @ 26.2.2012, 23:10) *
Ну ФСЁ!!!
Знаете, что-то вы перепутали пункты назначения. Мне неизвестен вами названный.
Но понятно ваше поведение. Показывает, что вы угадали.
ЁЖик
Хорошо хорошо...
Skaramush
Пример.
Ниже переписка:
Тема: детский сад
Переписку убрал, так как длинная цитата вышла бы.
Если я понял правильно, все вопросы заданы через интернет? Было ли хоть одно под подпись с передачей подписанной копии и ответа "выше и "копия в прокуратуру""?
Было:
http://zyalt.livejournal.com/467007.html
Там была одна замечательная парковка по адресу Старопетровский проезд дом 12 корпус 3. После того поста московские чиновники зашевелились, как змеи в гнезде. Даже собянинский канал ТВЦ показал мой пост в программе "Московская неделя". И вот чудеса начались. Теперь те же самые таджики закрашивают идиотскую разметку черной краской.
Skaramush
Цитата(ЁЖик @ 26.2.2012, 23:17) *
Хорошо хорошо...
Ёжик, как упомянул, моя работа в родной специальности состоит в том, чтобы наводить порядок. Там, где в мере и степени возможностей накосячили коллеги. Так что - почти два десятка лет, сплошная тренировка.
Кстати, без возможности заявить "это невозможно".
Цитата(ЁЖик @ 27.2.2012, 0:37) *
Ой! Знаете, у меня сначала было два браwзера. Потом было шесть. Теперь пять. И знаете, какой выкинул? Да да. Именно Оперу. Более тормозного бравзера, в жизни не встречал. При таких тормозах, все его услуги в области объединения с мобилой и прочим... спасибо не надо
А о чём сейчас? Ах да! О скрине. Так скрины лучше других делает Maxthon Browser. Безо всяких там утилит.
Нет не о том. А о чём? Ах да! О содержании скрина!
Ну вот теперь и составьте кальку обвинения (с какой-то там статьёй), по поводу содержания этого текста. huh.gif
В арифметику (если не в геометрию) уже поигрались. Теперь и в юриспруденцию можно. А чё. Время есть.
А вы похоже и впрямь из какой то Раши -Чебураши, а не из России. и кушаете вы не "гречку", а грибы какие то. Десять тыщ народа в метро на одну станцию входит знаете за сколь минут в час пик? каждые 45 секунд поезд, в поезде примерно 700 человек уезжает. вот и считайте. кто их заметил? Специальные фотокоры? Бибикнувший водила? Да пусть ходят, вдруг это те самые геи или любители химкинского деса, или борцы с коррупцией предложившие нехилую сумму за согласование места такого для такой разновидности митинга, или флешмобщики страдающие от тоски и жаждущие некоего единения. Лучше б с лопатами вышли и подчистили возле бордюров снег, а то новомэрские порядки уже сильно доставать стали- грязи много, а техника просто ездит изображая уборку. Вы не тормозили перед бобкетом вдруг выехавшим из за припаркованного камаза без всякого предупреждения? И такую уборку проводят ныне новые приведенные новым мэром дорожники. Да и заплатки ставят так же, оставляя за собой россыпь щебня возле заплатки, который потом летит тебе в лобовое.
Так вы о чем? О последней мирной демонстрации? Или просто о призыве к гражданскому неповиновению и незаконным немирным противодействиям?
Skaramush
Цитата(Vano @ 26.2.2012, 23:17) *
Было:
Это не чудеса. Это и есть реакция. И дожать реально, хотя и не просто. Но то, что есть уровень, которого если и не боятся, но опасаются - показывает, что не всё невозможно.
Да, через интернет.
Но через официальный сайт управы и сам вопрос и ответ считается официальным как бумажная версия. Ответ обязаны дать в течении 30 дней.
Что и выполнили.
Привел в качестве примера как работают чиновники.
ИМХО нет повода для жалобы в прокуратуру.
Пример того как составлена жалоба не правильно.
Софья пишет не нравиться сад такой-то, а в таком то саду дети дышат выхлопами с третьего кольца.
Будет ответ проведены замеры -воздух в пределах ПДК, не нравится - ваше дело.
Надо было с другого -
Мы ходим в детский сад - до него расстояние 1,5 км, нет общественного транспорта, приходиться с ребенком переходить дороги с интенсивным движением.
Согласно пункту такому - то СП Градостроительная планировка городских и сельских поселений расстояние должно быть не более 500 метров (к примеру) и тп.
Тогда и в прокуратуру можно писать.
Есть определенная сложность.
Это всё в масштабах города, мегаполиса.
Не в одной управе.
ЁЖик
Уважаемый Инж! Простите! А вот во всём этом вот... а где здесь про содержание текста скрина?..
Нет, ну геи метро и коррупция со статистикой... всё это конечно интересно... но ведь мы же-ж о другом кажется... Вот мне показалось, что Мы о тексте в скрине...
Skaramush
Vano, для этого либо изучается нормативная база, либо находится её знающий. Дорогу осилит идущий.
Как писал, да, канительно. Да, сложно. Но что поделать, такова селяви. И так выстроена, в том числе, "линия обороны" чиновника.
Вы очаровательны. Можете еще про что нибудь несвязное написать, тоже пройдет. Вам написали по ссылке конкретное, вы не поняли, вам скрин и подчеркнули в нем , снова непонятно. теперь про 10 тыс написать? Вам прохожих, который значительно больше на фото ничего не писать? Кто понял чего эти с белым стоят? Ну и пусть стоят себе- хоть в труселях,даже пусть и белых. От их пустопорожней демонстрации , что на 16 км периметра они замкнули 11тысячами народу для чего то, никому лучше не стало. детишки великовозрастные флешмобят, вот и весь их успех,пшик.
И как не крути все исчисления рейтингов, то у Пу-50-55%, а у всех остальных меньше в 1.5 раза в сумме. Вот и вопли о непризнании выборов. А за такое таких,ну супер популярных в народе, просто в годы 1922-27 положили б без суеты с пулемета и даже по 100 грамм потом не налили стрелкам. А ныне вон и не трогают.Нет у них никаких шансов, вот и порочат итоги выборов- перед своими избирателями пытаются форс удержать, бабки предвыборные отмыть, мы мол старались,но как обычно не вышло.
ЁЖик
Знаете, Инж! В таком-же стиле, я о чём угодно могу сказать, что : "это всё - ничто".
Не полемизируем... ораторскими изысками занимаемся...
не моими стараниями ("я вам этого не предлагал"©)
Да да. Согласен. По подписи в аватарке понял, что Вы - трудноуязвимый человек. Согласен. Вы в своей теме наладчик-реаниматор, я в своей...
И всё бы хорошо. Но тут есть один момент. Называется он просто: "и это пройдёт" mellow.gif
andrey R
Цитата(Hiro Nakamura @ 26.2.2012, 22:31) *
Ну тут не полное дублирование, почти все что говорят америкосы слышно хорошо. И на сколько мои скромные знания позволяют судить, переведено очень близко. А чтобы уловить оттенки и намеки язык надо знать smile.gif
Таки есть разница
http://avto-gear-online.ru/smotretonline/4...d-bbc-2012.html
Akirra
Цитата(HeatServ @ 26.2.2012, 19:21) *
Плакат дадут... Даже не надо знать его содержание... Там ещё с уралвагонзавода делегация немалая прибыла, взяли люди отгулы на работе, купили билеты и айда в Москау, кандидата поддерживать, кузькину мать "клоунам с болотной" показывать. Да, так всё и было.
Могут ещё у нас тряхнуть стариной, есть массовики-затейники, не угас ещё пыл в комсомольских сердцах, могут!
Ага, пыл не угас совсем... Людей с УВЗ выгнали практически "под дулом автомата". Едут все, кто в эти дни не работает, а кто не хочет ехать - ищите себе новую работу сразу - работать здесь вы не будете.
Учитывая то, что крупных предприятий в городе всего 2 и с работой откровенно туговато - последствия немного предсказуемы.
Kult_Ra
«Существо в кабинете» - безразличие и равнодушие
Когда ты приходишь к нему, у него первая мысль - а чем посетитель может быть ему полезен, что из него можно извлечь. biggrin.gif
Цитата(sonsumerek @ 27.2.2012, 0:12) *
тут вы правы
но...
у меня женская логика, извиняйте
когда говорят, что тетку изнасиловали, потому что она шла после 9 одна и в юбке - дура какая, сама виновата... когда говорят, что наркоман квартиру обнес - сами виноваты, собаку надо было заводить, они их боятся...
когда говорят, что сантехник накосячил при подключении унитаза - сами виноваты, куда смотрели
когда чтобы сходить к стоматологу - надо прочитать кучу литературы и понять что он должен делать и как и если будет делать что-то не то - бежать от него
когда идешь к врарчу - поставь себе диагноз сам
хочешь купить кондей - не надейся ,что тебе подскажут так как надо, сперва разберись в вопросе, научись их выбирать сам, сам научись их монтировать и смотри чтоб монтажники не накосячили...
а вам не кажется, что каждый должен заниматься своим делом?
Добавить можно - вы сами выбрали Правительство - бачили очи что покупали,теперь ешьте хоть повылазьте. Почему чиновник обязан обо мне заботиться? Это наивность юности. Это "мышление = молодым везде у нас дорога" проходит со временем. Жизнь приучила - Помоги себе сам - на Бога надейся, но сам не плошай. Не жди подарков от жизни, тем более от власти, чиновников. Это идиллия иллюзия, что ты, человек, кому-то "другим" нужен. Человек одинок во вселенной. Никто не знает, что такое хорошо и что такое плохо. Каждый замкнут сам на себя. Эгоизм (эго ест) превыше всего.
«Существо в кабинете» = Чиновник (выбранный или назначенный) или "служебное лицо" или "сфера услуг" пока ещё равнодушен ко всему, кроме своих интересов. Когда ты приходишь к нему, у него первая мысль - а чем посетитель может быть ему полезен, что из него можно извлечь.
Кто ведёт себя по иному, тот борется с ветряными мельницами! Селя ви. Бороться с тем, что есть «Существо в кабинете» = бороться с ветряными мельницами. Есть только одна возможность реальная - самому не делать подобного.
«Существо в кабинете» не изменилось за время моей жизни. Что было оно в СССР, точно такое же оно и сегодня. Меняется только название кабинетов и должностей - люди и их повадки/помысли не изменились. Суть не изменилась - на словах одно, в деле другое. Меж словом и делом - пропасть. Сладко словами стелят, но ложе "для спать" делается жестким.
Рассчитывать по жизни можно только на себя. Тут, Вы, Света, не ошибётесь в выборе.
sonsumerek
такая манипуляция меня давно уже не цепляет )
это факт ))
andrey R
Цитата(andrey R @ 27.2.2012, 10:07) *
Андрей Анатольевич, Вы не верите что так может быть? Да легко, вертикаль выстроена как надо. Руководителю предприятия тоже, знаете ли, не сбоку пришло, а по вертикали. И руководитель знает, что лучше лишний раз людишек сгонять помитинговать, а то свято место высшего менеджера пусто не бывает.... ну, а под дулом или пряниками гнать это уже от способностей руководителя зависит, да от кубышки предприятия. На уралвагонзаводе кубышка нормальная, людишек привезли, наверянка за счёт заведения, поили и кормили тоже наверняка от пуза. Ну не бывает чудес, не сорвать нашего электората так просто с места ехать в столицу и поддерживать кандидата на трёхчасовой митинг. Только пряники или дуло.
andrey R
Причем тут вера? Я хочу фактов, а не призывов кому-то поверить. Факты есть, или опять, как с "фальсификацией выборов", одно бла-бла-бла?
CNFHSQ
А на слово поверить не бывает? Это только у Александра на все готовые ссылки. Интереснее факты с мест, и ссылки тут совершенно не нужны.
EJIEHA
Вызывает сомнение факт наличия "дула".
andrey R
Где факты с мест? Я не вижу. Вижу голословное утверждение.
Только вчера вся неполживая пресса трындела про "замкнули круг". Нуичо? Посмотрел фото от очевидца. И близко не лежало, нагло врали. Мне что, надо не верить своим глазам?
EJIEHA
Я думала народ сегодня документальный фильм BBC, который на выходные показывали, про "нулевые" будет обсуждать. А тут снова здорово - кого и куда на автобусах возили...
CNFHSQ
Что людей согнали, здесь как говорится и к бабке не ходи, не первый год живем.
И меня это мало волнует, всегда так было. Еще студентом выгоняли Садата встречать на Ленинском.
Фактов чего? Факт наличия многотысячной толпы с уралвагонзавода присутствует? Неопровержимо. А дальше простая логика. Вы рабочий уралвагонзавода, допустим, Вам нравится Путин и не нравятся "клоуны с болотной", Вы копоть-сажу смыли под душем, съели холодного язя, и пошли покупать билет на поезд и на митинг в Москву? Жене это сможете объяснить? Мол, не пить я туда поехал, от чистого это сердца исходит, да не реви дура, шубу потом купим, сейчас нужно политический вопрос решить...
andrey R
Ага, щаз-з... biggrin.gif Эт же смотреть надо, и не соврешь, что сурковскаяпропаганда. Гораздо приятнее верить, ибо к бабке не ходи laugh.gif Железобетонный аргумент для верующего...
Akela
Прочитал про претензии к детским площадкам, садикам, парковкам. П.....ц!
"Крыша течет - Советская власть виновата!"
Что ж за мания такая в русском народе все соотносить в фигурой лично царя. Вот приедет Путин - сделает нам садик (парковку, площадку, дверь в подъезде...). А местная власть на что ??? А Вы лично на что ??? Ходите, пишите, требуйте. Добиться правды можно всегда. Да, нелегко. Да, долго. Да, требует юридической грамотности, настойчивости и тд. А иначе ничего не будет.
Не надо спрашивать "Что государство сделало для меня?" Надо спрашивать "Что я могу сделать для государства?".
И так называемые "развитые государства" именно так и живут. Или вы думаете, что там манна сама неба падает? Прежде чем она начала падать (местами и не для всех) были пролиты реки крови и пота.
Кстати о площадках - у нас в районе за последние годы создан детский парк, универсальный спорткомплекс с бассейном и прочим, 2 развязки, вода горячая стала круглосуточно.
andrey R
Ах логика...ну канешно, как же ж это я оплошал то? smile.gif Факт наличия болотных есть. Не иначе язя покушали и на площадь поперлись, политический вопрос решать по зову сердца biggrin.gif
Наши либералы, они такие ... либералы smile.gif Жить и работать хотят, как привыкли в проклинаемом совке, а вот чтобы свободы и права, да и зарплата - как в европах. Загадочная русская душа smile.gif Даже Ливией не напугать, ибо веруют, что им от Господа это всё положено, за глаза их красивые и прекрасные намеренья smile.gif
Мамой клянусь, хочу работать, тока режим кровавый не даётъ, а так я чуть что, так сразу biggrin.gif
LordN
слухаю радио.
йехомасквы, радиоманьяк и т.п.
слухаю и чувствую вполне сложившуюся закономерность.
вот что хотите делайте - обвиняйте меня в предвзятости или еще в чем подобном, но, как только идут передачи про политику и принимаются звонки от слушателей, то любой истеричный голос с невнятным текстом сразу обо всем на тему "просралиполимеры" - против путина.
любой спокойный, со внятной аргументацией - либо за, либо скорее за ввп.
ну может и не любой, но соотношение не хуже чем 10 к 1 это точно.
у меня есть знакомый, такой же ламер в политике, как и я.
в декабре он был ярым противником ввп.
ярый слушатель и почитатель йехимасквы.
давеча, в разговоре под пиво сообщил, что полностью поменял свою точку зрения и очень благодарен за это радио йехомасквы втом числе. они почти в одиночку убедили его в том, что путин рулит, а все остальные *-ы smile.gif
после этого сидел и думал - може и впрямь нас дурачат и водят за нос, а насамделе катают всю страну по какой-нить отработанной методике нлп? и все шобла в доле - все эти немцовы-химлес-жирик-зю и длинный алигарх. белые ленточки и прочее и прочее...
но как-то слишком круто замешано, слишком большие массы людей, слишком большие числа, неужели все настолько предсказуемо в человечьем стаде?
Bеликий
Вы телевизор смотрите? dry.gif На выходных много других интересных дел.
EJIEHA
andrey R
Да всего лишь Пу оказался умнее всех этих неполживых. Они ж по кальке работают. Раньше везде прокатывало. А он взял и просто дал им трындеть от пуза, дабы дурь их каждому стала видна. Они аж на ОМОН бросаются, аки Курицина знаменитая, а ОМОН их всё не бьёт и не бьёт.
Вместо головы Гонгадзе - подмётка Удальцова. Вместо "широкого протеста народных масс", хомячки да геи в белых лентах. Не выходит ревогюция в таких нечеловеческих условиях, один балаган smile.gif
LordN
про автобусы, увз и т.п. - я считаю что это ну очень плохо, когда власть может только так и показать свою значимость. но с другой стороны, я б вот ну не пошел бы на тот митинг, ибо лениво. другими словами - в том что там были автобусы с увз можете смело винить и меня. виноватый, каюс. но, считайте, что те бедолаги были там и за себя и того парня из томска которому лениво и денег на билет никто не дал. smile.gif
в уме этому парню не откажешь.
Akela
...сидел и думал - може и впрямь нас дурачат и водят за нос, а насамделе катают всю страну по какой-нить отработанной методике нлп? и все шобла в доле - все эти немцовы-химлес-жирик-зю и длинный алигарх. белые ленточки и прочее и прочее...
но как-то слишком круто замешано, ...
Вот-вот, и у меня такие мысли появляются. Может на самом деле вся эта "несистемная оппозиция" - на самом деле агенты Кремля ? ph34r.gif
Рейтинг власти в народе объективно упал (по сравнению с "ранним" Путиным). Вот и было задействовано "пугало" - народ испугается оранжевой революции и сплотится вокруг вождя.
А с другой строны - уж больно сложно все это. Результат может выйти из-под контроля. Да и Навальный то за американские деньги в Йеле учился.
Так может в Вашингтоне тоже агенты Кремля сидят ?
КОНСТ
Ну что, еще неделя и весеннее обострение пройдет? А нет, не сообразил, конечно же, 11 марта будет митинг под лозунгом "выборы сфальсифицированы!!!" (не того выбрали!!!), причем заявка будет подана ДО оглашения результатов выборов (а то еще и ДО самих выборов!)
CNFHSQ
Да об этом и речь. Показали силу, организовали массы. Пропаганда ведется так, что люди мнение меняют. Как все эти одобрямс делается все знают, все пыль в глаза хотят подпустить. Ну и слава богу, все люди.
НО доказывать здесь....что все в едином порыве, прям странно да и непонятно зачем!
